02 stock track times
My owners manual says the Lightning runs a 1/4 of 13.9. I have read either on this web board or the world Lightning forum that some have gotten their stock Lightnings to 13.4 in the 1/4. Is the Lightning under rated or is 13.9 the actual time that my truck should run?
And with the area that I live in the closest track is an 1/8 mile track. What kind of times should I expect from this track?
Most guys/gals are getting around 13.7-13.9 in good cool air w/a decent track. Some have gone quicker but I question "stock". I am calling "stock" as delivered from the factory w/all fluids and pressures at OE levels. (tire psi, oil, motor temps, boost psi, ect..)
A 13.9 1/4 should equall a 8.8-8.9 range.
I'm going to run my bone stock 02 this upcoming Fri and will post afterwards with details of my findings. I just hope it's cool and dry so I can see some 13s in "stock" condition.
WOT
WOT
My local track is 660ft above see level and it was about 60 degrees outside. I dont know what the corrected altitude was.
I ran a 13.27@102mph and backed it up with a 13.29@102. ALL stock on F1's
Two weeks later I ran a 12.62@107 with a 4pound pulley, JDM chip, K&N filter in modded air box and E.T. streets.
Jason
Jason
I ran a best stock of 13.446 @ 102.73 mph completely stock with tow hitch and all. weighed in at 4867. it was very cold that night...in the 40's and it was snowing every other now and then. truck had 2000 miles on it. since then i've run 13.5x consistently. i'm getting a JDM stage 1 L kit in it this friday. i also dynoed stock at 354rwhp and 422 rwtq.
