need help, major problems!!!
Old 07-24-2002 | 05:36 PM
jkoon's Avatar
installed a 5lb pulley a few weeks ago. took the l to the track and didn't see any improvement. The truck seemed sluggish and sputtered when running 55mph or so. I sent my chip back to have it reburnt(diablosport). Now the truck runs stronger than it ever has. However when it shifts into drive at wot, i get the worst valve chatter i've ever heard. Im still running stock plugs and that may have something to do with it. ive got tr5s in the shop waiting to be put in. but could the plugs be causing this terrible chatter?
Old 07-24-2002 | 05:57 PM
Tiamat's Avatar
Get it looked at soon by someone you trust soon. Don't screw around, these motors go boom easy.
Old 07-24-2002 | 06:00 PM
captainoblivious's Avatar
I can't say if the plugs are causing the problem, but a 5lb pulley and stock plugs are a NO-NO, even the tr5's shouldn't be put in. Go with the tr6's. And don't drive the truck hard until this is fixed.
Old 07-24-2002 | 06:37 PM
Silver-Bolt's Avatar
TR-6 or colder.
Old 07-24-2002 | 06:51 PM
jkoon's Avatar
i just ordered tr6s around five minutes ago, but what should i gap them at and what is the chance that will fix the problem?
Old 07-24-2002 | 07:18 PM
Tiamat's Avatar
Like i said before you need to call one of the tuners and ge the info. I dont know what the other tuners do but JDM installed tr6's with my 4# pulley.
Old 07-25-2002 | 04:03 PM
Don's Bolt's Avatar
Gap the TR6 between .40 and .42
I have mine at .40
Old 07-25-2002 | 04:08 PM
builtfordfast's Avatar
Yep, what Don said !
I have the 4# and my tr6's are gapped at .042
Performance Mods
JDM flip chip . JDM cold air induction . JDM 4 lb. interchangeable lower pulley .
JDM boost bypass . Oil breather cap . Ngk-Tr6 Plugs@.042 gap .
Inline valve body . Deep sump pan and filter .
Appearance Mods
Stull billet grille . Bullitt gas cap . Astrocap lid . Ground Force 2/1 lowering kit .
20% window tint . Herbs washers . Lightning floor mats .
Lightning website
F150online gallery
Have a great day eh ! .................................................. .......... Dave
Old 07-25-2002 | 04:39 PM
LightningDammitt's Avatar
uhhhhhhhhh----
Let's not forget the obvious!!? Did you get the chip tuned for a 5# pulley?
If not, don't drive it much until you do...
Old 07-25-2002 | 04:50 PM
jkoon's Avatar
its burnt for a 5lber. my 1st burn seemed sluggish and the truck wanted to miss and sputter when running around 55mph or so. the truck doesnt chatter all the time. i tried it from a 60 kick and it did wonderful. it does fine going from a stop until i reach around 100 or so, then it sounds like its gonna come apart. could my boost actuator have any thing to do with it? ive got it turned up real high.( i mean a 1\8 to a 1\4 inch off the stop.) im just real worried about it. ever since i put the pulley on i havent had anything but problems. if any of you know a tuner around tennessee or north alabama that could look at it i really would appreciate it.
Old 07-25-2002 | 05:40 PM
beefcake2002L's Avatar
Registered User
Re: need help, major problems!!!
You put your truck into drive from park or nuetral while at WOT??????
You do mean when it shifts gears right?
Old 07-25-2002 | 05:45 PM
brasil's Avatar
Like Don said tr6's gapped at .40. You might also need a better fuel pump in order to provide the extra fuel needed with a 5#, so you don't starve the engine for fuel.
Later
Old 07-25-2002 | 05:47 PM
jkoon's Avatar
i put the truck in drive, put it to the floor, runs fine until it shifts from second to drive. ive gone from a 60mph kick and it does fine. i guess it builds more boost from a dead stop than from a 60 kick,i dont know
Old 07-25-2002 | 07:41 PM
Ruslow's Avatar
Can we say LEAN!!!If it still does it with the trs in it you are to lean and it is pinging!!!Cyl temps are getting to high that is why it takes you till 100 to start to notice it.With your foot in it that long the cyl's have absorbed all the heat they can and they are telling you that.I know from experience on that one.Stan
Old 07-25-2002 | 08:30 PM
jkoon's Avatar
id like to thank all of you for your help and opinions they have given me several ideas of what the problem may be. all of your input is greatly appreciated.
Quick Reply: need help, major problems!!!
