urgent engine oil question
ok i know this is a stupid question and i shouldn't even be able to own a L for asking but....
the dipstick for the engine oil shows my level at "min"..below all the xxxxx grooves...but my engine oil light doesnt come on...so when does it come on? and should i refill my engine oil or is it not a problem....was it just not filled enough when it left the dealership? (i have 500 miles on it now)...and also what should i refill with...meaning what original oil does the L use? i need brand, weight and everything..
also, is it alright to switch to mobil 1 synth at 500 or 600 miles or should i wait a bit? and should i switch the oil filter as well? whats the best brand? i hear purolator 820S is awesome...any opinions?
just wanna be safe with everything...
thanks for bearing with me!
There is no check oil light that I'm aware of. When you change the oil and filter replace with exactly 6 qts. It should be 1/2 way between min and max. Do NOT fill to the max line. Every 5.4(even N/A versions) that I've seen show the level in the middle when they are full. Overfilling can result in foaming and loss of oil pressure and performance. It sounds like yours is where it needs to be. Some cars come from the factory with the Mobile 1 in them so it's debateable on how long if ever to wait. I waited 2,000 before changing and went to the Mobile 1. Purolater makes the Ford filter BTW.
The only questions that are stupid are the ones that never get asked.
Only 5 1/2-6 qts--no more! As said, 'full' on our engs/dip sticks is about mid-way between the max and the min marks.
I changed oil at 1,000 miles using Motorcraft 5W20 and their filter. At 4,000 miles, I changed to Royal Purple's synthetic 5W20 #11 Racing oil and a K&N Gold filter. Never had a noise or useage problem--now at 31,600 miles.
Dan
Dan
Originally posted by cyntaxx
i've heard that i'm pretty safe running the oil level that i am now and that some run one qt less at the track even just so it doesnt splash on the cranks, etc...
am i safe or should i be running to the store asap to get oil?
like i said, its right at the letters "MIN"...
