Magnaflow Muffler
I use the 12568 which is longer (ablot same length as the stock muffler) because Jim at JDM said if you use the shorter one 12468 you will actually loose power due to the lack of enough backpressure. The only prob. w/ the 12568 is that it's barely louder than stock. I will hopefully be soon ordering a silver bullet
Later
Later
Go on ahead and buy the 12468...
Originally posted by brasil
I if you use the shorter one 12468 you will actually loose power due to the lack of enough backpressure.
Later
Later
The Stainless version looks mo-exactly for a very short time, but really, how many people notice the illusterious mirrored case after a few hundred miles?
They all look alike after a good rain storm anyway's. Save your money and go with the 12468 Then you can buy a PSP lower pulley with the money saved
i just quoted what the folks at JDM told me. They have done numerous dyno testing w/ most exhaust systems and mufflers out in the market. Why do you think they do not carry the 12468, but they do carry the 12568? The 12468 is shorter, thus louder, but it does cause a slight loss in power. The 12468 would suit a non supercharged engine that does not need to move as much air out.
Later
Later
Q: 12568 vs. 12468?
A: tail pipes are easier to work perhaps?, jim's personal preference? cleaner install?
Now, back to the point
Supercharged applications need MORE back pressure than a naturally aspirated one?
so in essence and AGAIN keeping with this point of view, a set of long tube headers (one set of cats must go) and a 12468 actually causes power loss? Maybe on a stock truck.
no flame dude, just need clarification.. Sounds like someone blew smoke into your posterior region.
