Having Ford alarm trouble
I unhooked the negative battery cable to do some work on the truck. When I hooked it back up the remotes no longer work to disable the alarm. They lock/unlock the doors fine they just no longer activate/deactivate the alarm. Problem is the alarm is stuck on. Only way to start the truck is the hit the override button. Any ideas?
Originally posted by Crazyone
"override button" ???
to my knowledge there isn't one on the ford ones. It uses the doors key cyl(has a switch in it that disarms the alarm) So are you sure its a 'FORD" alarm and not an aftermarket?
Brandon
Brandon
Yep it's a System 4 Ford alarm installed by a Ford dealership.
I guess that is another weird thing. The alarm is armed, the light is flashing, but the siren doesn't go off when I open the doors. All it seems to be doing is disabling the starter. Interesting.
All the manual says is to take it to the dealership if it doesn't work right. Hoping someone here will know what to do...
