Chip ?
Working loose can happen once in a while but it is not a 'common' problem. I had one break contact even though I had taped it to the PCM--turned out to be faulty chip contacts and the tuner replaced it. If you clean the contacts(PCM) properly, insert whichever chip you are using firmly making sure the contacts line up,form the rear lip of the inside PCM bracket away from the chip(although, I have never had to do this--some do), use good Duct tape to secure the chip to the PCM, and reinstall the black, nylon PCM clip(holds the PCM to its bracket at the rear), you shouldn't have any "shaking loose" problems.
Don't deny yourself the 'rush' a chip can give you...........get one--or three, like I did .
Dan
Dan
