295/45/18 nitto drag radials???
I have a set and can say with the right conditions they will hook but if you are putting some serious power to the ground like my truck they are not worth it. Before I had traction bars with the Nitto darg radials they helped break a drive shaft. The size is 305/45-18. I will give mine one more chance before I get some hoosiers on hopefully the track will have some traction.
www.discounttiredirect.com
$480 for two Nitto Drag Radial 555Rs 305/45-18 shipped.
That's the best price I've seen yet, because if you are in CA Victoria Tire charges 8.25% for tax. Where they came up with that rate only Gray Davis knows.
_______________
Cliff '01 L
_______________
Cliff '01 L
I have the Nitto 555R's 305's also.....in the heat they hook on the street pretty well....but under about 65 degrees, they spin as bad as my F1's. And my problem with spinning is the 1 to 2 upshift..with the Nittos they chirp when its hot out....otherwise they just spin and I have to let off.
Hey Rusty,
Sorry I didn't post sooner, I am having laptop computer problems. I have the Nitto's, 305/45/18 on the rear. Best 60' was 1.71 in Feb. 02 this year.
I sold my 20's and use the Nitto's on my truck for the street. I have bought a set of Hoosier DOT Quick Time Pro's for the track. If I want to race in a hurry, I'll just keep the Nitto's on.
I love them on the street, they do pick up small rocks and sling them though.
Discount is where I got mine. See you at Bristol, TN this weekend???
