spark plug tool? anyone used it?
You don't have to remove the fuel rails but you have to pull them of the fuel injectors. I just pull the rails off to the side. I also pull the injectors but leave them hooked up and just swing them out of the way. I remove the coil packs cause they can get in the way when hooked up. I also remove the air inlet tube up to the throtlebody and the braket that holds the sylinoids and other stuff. You will allso want to remove part of the braket for the power steering reservoir. Also when replacing the plugs be carefull only put them in by hand so you don't strip the threads and snug them up and when you tighten with a ratchet only a 1/16 of a turn is needed.
