Is it possible to run caster/camber plates on our L's like mustangs can?
I was looking at my fiance's 02 gt yesterday and the strut covers look real close. is it possible to put on a set of hotchkis or bbk caster camber plates? i would want them souly for looks. Thanx
Lightnings don't have struts. You can add cam bolt kits to achieve some adjustability. You will not get as much as camber plates, but the same concept.
Originally posted by Silver-Bolt Lightnings don't have struts. You can add cam bolt kits to achieve some adjustability. You will not get as much as camber plates, but the same concept.
With the washers from Herb and cam-bolt kit, I got -3 degrees on the front camber.
