SC Replaced at 6500 miles on 02L
I started hearing a noise which I thought was comming from the engine. So I took it to the dealer for the noise and the driver seat wear problem. I was shocked when I picked it up and found out they changed the Super Charger and Plenium. It took away the noise and the engine runs quieter than ever. One thing all of you should check. The oil level in the SC. The tech said mine was low. I don't know if this caused the problem or not.
Hey guys,
I do the pre delivery inspection up here for the local svt dealership and I have had 2 come in with low oil in the supercharger, filled them to proper level and sent them on there way, no leaks just low from factory, ohh and the noise kinda sounded like a bearing starting to go a little whine to it, no throttle of course just at a idle and constant..
Hope this answer's your ques....
later..
later..
Originally posted by junehhan
Hold on, according to the instruction manual or maintanence guide that came with our vehicles, it states to check the level of the supercharger oil every 30k miles
