Brembo rotors
Brembo rotors
I found replacements for the Brembo rotors. www.stoptech.com
They have direct replacements in stock 355mm x 32mm cross drilled rings for $279/ea. They also sell the mounting hardware kits for $40/ea.
I picked up Hawk pads HB193.670 form Pegasus for $109/set.
Best Brembo price I found on the rotors was $355/ea and on the mounting kits was $125/ea. Could not get any responses from the leads you guys gave me.
Disclaimer: This is for Brembo users only. Will not work with factory brake systems.
I saw the ones on tire rack...green stuff and their red one also. Hawk HPS and HP plus...
I'm just using cheap Valvoline dot 3/4 fluid for now. It has a fairly high wet boil. Not as good as ATE. Since I don't autocross I don't care too much.
I'm going to try some new pads here before long. I don't think the HPS are working too well. The brakes seem as if they fade and pumping doesn't help. Fluid was changed last week...Maybe new rotors would help. I read Stans article that was posted awhile back.
Oh great I have the HPS pads coming. Let you know how they do on new rotors. I was also looking at the green and red stuff at the Rack also. I will try the HPS first. The Ford service manual on cd claims that if anything other than DOT3 fluid is used it will harm the system. I am assuming they mean mixing different DOT grades vs a complete flush and refill.
I'm running Brembo's street/race pads at the moment (I got 3 sets with my brakes when I bought them).
For fluid I'm running "Neo SuperDot 610". It works in Dot3/4 systems.
Wet is 421, Dry is 610... $12 per 12oz.
http://www.bakerprecision.com/neobrk.htm
Good find on the rotors... Any news on the rears?
