Extrude Hone
Extrude Hone
I have been reading up more and more about this, and i have decided it would be worth my time and money to have my upper intake done. I have run across a few questions being inexperienced at port N polishing, but I am learning thanks to the help of my L buddies . Hopefully you can help me with my questions:
1) What tools would I need to do this properly? (dremel, flapper?, sandpaper)
2) I read in another post of people using a dremel to "port match", why cant I just bolt the intake back on?
3) How much do I need to sand the interior?
4) What do I use to polish the Interior after porting?
thanks for your help guys, we all gotta learn things we dont know sometime, and for me that time is now.
thanks again,
-Jeff
thanks again,
-Jeff
An extrude hone machine, I believe is really really expensive. Dremels and a flapwheel is the next best thing.
Read this and all links contained in it:
https://www.f150online.com/forums/sh...threadid=87698
I did mine, pretty easy to do just reallllly dirty.
Dremel with flex shaft will work, flap wheels for dremel and I then used a small buff wheel (1-2") with greaseless compound in 80/220/320 grits. This smoothed everything to a very smooth finish. Last I attached the TB back to the plenum and used a marker to mark the material that need to be taken off the plenum for a flush fitting. Took apart and used same flap wheel to sand the material off.
Took a few hours to complete. Do it outside as it will get really dirty fast! Not as nice as what you can buy but alot cheaper
Extrude hone machine
The hard way:
First, buy 100 lbs of diladent compound 3179 from Dow Corning($800 + shipping).
Second, remove your intake.
Third, shove the Diladent compound (aka silly putty) through the intake at high pressure/low volume (your fist with a lot of exercise will work!) Flow a couple hundred cubic feet through it.
Fourth: Finish up with a dremel and flapper wheel/port matching.
Easy way:
send it to www.extrudehone.com
Coldie
Easy way:
Coldie
There is a guy down in FL that will smooth it out for you (not extrude hone, but close) for about the same price. He will send you a ported/smooted plenum that you can install on your truck and then you return your core afterward. That way there is no down time. Email me if you want his name. I don't want to violate vendor rules (I'm not one nor associated with one nor paid by one). If it's ok to post his name and/or information, somebody please let me know. Otherwise, email me and I will give you his info.
Also, he'll do some clean up work on the stock TB (he'll send that as an exchange unit at the same time) as well or match it to an oval TB if you send it to him or buy one from him.
Ken
Ken
