The Original and Best Electric Fan Design for our L's!!
#32
#33
Originally posted by Deus
So uhm...how is this the best fan kit? If its all ford parts where does JDM come into the set up? I mean why can't your average gent just buy the parts for this 'kit' from ford?
Tim
#34
JDM's Fan blows away the competition!!!!
Just took advantage of Jim's last special on the SVT board. Kit and pump go on in a breeze. This is set up unbelievable. Looks stock. Only thing you have to be carefull of is when tightening the nut on the temp sensor that goes in the block. It's a plastic housing and if you overtighten it, it will snap!!!! My friend gave me a hand and way overtightened it. Thanks again to Jeremy for ups reding that to me!!!!
Just of ****s and giggles. Put on the JDM fan/water pump kit and an accufab throttle body at FFW last weekend. Temps were topping 100 degrees. Not only did i match my personal best, but I dropped it from 13.5 to 13.3 and my mph were up . Had nothing to do with the prepping of the track because my 60's were the same. I would attribute this to the fan kit / pump keeping my cool!!!!
By the way Deus, JDM did all the R&D to put these ford parts together to work on our trucks as a kit. Ford for some reason felt this was a waste to put on stock. Go figure. That's what these aftermarket vendors are for and how they make a living.
#41
truckn,
Actually it was my idea. Seeing how our sales staff is so swamped with calls I figured since we sold so many of these I might as well put the numbers up here so we don't get hammered with even more people asking for tracking numbers. I think it was a good idea.
BTW- You need to reread the original post very carefully and slowly. You get the water pump for free plus $10 off the fan kit itself.
Thank you for your interest truckn.
Justin@JDM
Justin@JDM
#43
