Clearance between stock fan and radiator.
I havent had my truck for 7 months now and cant remember how much space there is between the stock fan and the radiator. Im asking because I want an electric fan but I will always be worried that something will go wrong with it and I will have no cooling. So I was thinking of keeping the stock fan and adding the electric one(Flex A Lie). Is there any reason why I cant or shouldnt do this?
I was thinking of keeping the stock fan on there and adding the flex a lite unit(which is two fans built into one shroud)
http://www.flex-a-lite.com/auto/270_280.jpg
I agree that two fans seem to be overkill. But, you could put a "pusher" type electric in front of the radiator and A/C condenser. If I were doing this I would not put a shroud on the electric so that no air is blocked.
Also, it is rare, but clutch fans can fail. I have had it happen to me. You end up replacing everything on the cooling system first because you don't think about the clutch failing.
