DENSO or NGK
DENSO or NGK
Just changed to the 4lb lower pulley and was curious as to which plug would be better for a daily driver with the odd trip to the track?
DENSO IT 22 or NGK TR-6
Thanks,
HORSE9
AIRAID KIT
JDM Flip chip
Amsoil Synthetic
Oil Breather Cap
Boost Bypass Kit
Single Blade Throttle Body
4 lb Lower Pulley Interchangeable Kit
Line Mod Valve
Deep Sump Trans Pan & Filter Kit
Jet Coated Long Tube Headers
Twin Magna flow Full Muffler System
Electric Fan Kit
Cobra R Water Pump
Drive Shaft Loop
12.9 @ 107
NLOC #806
Thanks,
HORSE9
AIRAID KIT
JDM Flip chip
Amsoil Synthetic
Oil Breather Cap
Boost Bypass Kit
Line Mod Valve
Electric Fan Kit
Cobra R Water Pump
Drive Shaft Loop
12.9 @ 107
NLOC #806
Don't skimp on your plugs.....
Don't go with the NGK's becuase they are cheaper...I did and it cost me more money in the long run.
The NGKs are better than the stock plugs, but I still had some random misfires. I ended up going with the Densos anyhow...Richard (ICULOKN) steered me in the right direction...thanks Richard
Once I made the switch, there was a world of difference!!! No more misfiring, smoother running...much better. They still run perfectly after 5K miles and countless 1/4 mile runs.
