160 degree thermostat install
Not all the way
You should not have to drain it all the way just below the level of the housing for the T-stat so say half way to be safe the just take off hose(just side to housing) and housing (dont lose O-ring) pop the new bad boy in tighten it up fill the coolant res again and your good to go
Good luck
Slick
sorry no pics
Good luck
Slick
sorry no pics
Thermostat
I just installed my 170* thermostat last weekend and it was very easy to do. It took me about 30 minutes from start to finish.
the first thing to do is drain the radiator about half way, then remove the throttle cable and shift cable, unbolt the bracket that hold both cables from the bottom of the throttle body and move out of the way ( 2- 10 mm nuts ) next remove the bolt from the top of the thermostat housing that holds the power steering bracket ( 8 mm bolt ) next unbolt the thermostat housing ( 2 long 10 mm bolts ) carefully move the power steering bracket to the right while removing the thermostat housing pull the old thermostat out and put the new one in and put it all back together in reverse order refill with antifreeze and your done.
Larry.
Larry.
With the eng/radiator cold, attach a vacuum hose to the nipple next to the drain nut on the lower rt. corner of the radiator and drain out(you need a low-sided container) 1 1/2-2 gals of coolant. This way, you won't spill a drop when you remove the 'stat'. After the install, start the eng. up and pour the coolant back into the reservoir. Pat self on the back .
Dan
Dan
