TPS Aadjustment
TPS Aadjustment
I was wondering if anyone knew how to adjust the TPS sensor resistance, or is it preset nonadjustable. There is two bolts that hold it in place abnd if you loosen them you can slide it in a circular pattern a little changing the resistance and therefor the voltage the EEC sees. I was wondering if anyone knew how to ensure it is set correctly. There are three connections on the TPS labeled A, B, and C. If I knew what full closed reistance should read and on what two wires to check it on I could set it. I would rather use reistance and set it while I have it off the truck. Does anyone have any input on properly setting the TPS sensor??
Re: TPS Aadjustment
do a search and you'll find an article by clonetek.
Re: Re: TPS Aadjustment
This is awesome functionality by the way... I wonder why google.com doesn’t make you enter search terms that are greater than 3 letters? Maybe usability IS a goal of theirs.
Here's the thread: https://www.f150online.com/forums/sh...ghlight=tps%2A
You can always use the asterisk (*) to make up the 4 characters for searches.
Bob
Bob
