4 Pound Pulley Question??
Originally posted by Rob_02Lightning
svt360
I have the complete chart that shows every pulley and all the specs, but it's on a spread sheet. When I post it here it getts all screwed up.
I will try and figure out a way to post it
svt360
Thanks and I appreciate it!
Is there any worries about running a 6# vs. 4#?
/tg
Joe got mail Jack.
Freak-150, I asked myself the same question over and over.
The reason for it is not so much how it runs, the stock plugs run great with the 4Lb Pulley. The problem is that the added Pulley creates more boost AND MORE HEAT. The stock plugs AFTER A WHILE will start to melt and oviously cause problems, SOMETIMES REAL BAD COSTLY PROBLEMS. If you stay off the WOT boost you can go a few weeks before the change. But I've seen enough pictures of melted plugs to realize I HAD TO CHANGE THEM.
It's a bitch doing it yourself, but after your done, you'll feel proud and have a much better understanding of your ignition system.
Well worth the few hours it'll take.
Can someone email the file to me too, please?
james@jwatson.net
Also, I noticed that I had to zip the spreadsheet before I posted it here. Not sure why, but as soon as I did, the d/l worked just fine.
Thanks!
James
james@jwatson.net
Thanks!
James
Re: 1/4 mile times
Originally posted by Silver 2002
No, I do not have a track near where I live therefore I cant go.
the one in monroe is good, and the one in shreveport is DAMN good..
http://www.twincitydragway.com
http://www.redriverraceway.net/
we even go to hallsville from time to time... it's about the same distance as the shreveport track.
http://www.hallsvilleraceway.com/
