Anyone with Johnny Lightning Line mod valve?
if you have a JLP line mod, how do you like it? i have one sitting in my closet and im trying to decide whether to just try it out or buy the factory tech valve body. im kinda leaning towards just installing it and seeing how i like it. just curious how others like it.
I just ordered mine Monday, hopfully I will get to install it this weekend along with my 4x4 tranny pan & filter. I also considered the FTVB, which I know is better, but I wanted to try the $40 line valve before spending $200 on the FTVB.
I will let you guys know all about it after the install!
Originally posted by 02Thunder
It will work great till the paks are glazed, then it be just as mushy as the stock setup. have fun while it lasts.
Check out this thread over at ****** concerning this.
Dan: yeah, I just decided to try the line $40 line mod valve instead of the $200 VB. If I am not happy with the results, I will get the VB. Just a little experimentation
I have one with the deeper tranny pan and I love the way it shifts now, though if I get on it hard and don't heat up the F1's they spin at each shift. A cheaper mod than the valve body since both decrease your tranny life I'd spend less or put the $200 toward building up the tranny to handle the torque and horsepower of your truck.
Bottom line...
Line Mod Valves
Complete Valve Bodies
Shift Kits
Chips with Increased Line Pressure
These will all thrash a transmission over time. Some faster than others. And doing anything short of rebuilding with built internals (i.e. Kevlar or other hi-po material'd clutches and steels, hardened shafts, etc) any transmission will fail from the torque and the racing conditions we put them through.
So if any "Tuner" or "Builder" tells you their's is special, mark the calendar date down, and start counting your days. It will happen, its the nature of the sport.
joe
Line Mod Valves
Shift Kits
joe
That is why we all should leave in the torque reduction in our programs. It is there for a reason. Removing the torque reduction is probably MUCH more detrimental to the tranny than any shift kit. Instead of completely removing the TR, maybe reducing the duration would be better.
Shift kits are supposed to EXTEND the tranny life, not shorten.
Any device that makes the shift of an automatic vehicle occur faster, does NOT lessen the life of the transmission. In stock form, the engagement of the clutch packs has a certain amount of "slip" engineered into it. The vehicle manufacturers base how much slip on what type of vehicle. A Mustang for example, will have much less slip of the packs because it's a "performance" car, and it's expected to have a firm engagement. However a Cadillac or a Lincoln has tons of slip, because it's a luxury car and the customer should feel as little of the shift as possible. That's why most luxury cars need trannys around 100k. Slippage causes extra wear on the clutch discs, and also causes hot trans fluid temps. By making the shift occur faster, you limit slip, and therefore you have less wear on the clutches, and lower fluid temps.
1.) increasing line pressure
2.) reduction of clutch pack slip duration
3.) elimination of the 8-4 cyl drop
4.) all of the above
5.) some of the above
Hope I'm not getting way off track from the original post.....If I am, I apologize to the original thread starter.........but this is something I have never really been to clear on, and this sounds like the perfect thread to discuss this.
thx again,
JC
A chip can be programmed to shorten or eliminate the torque reduction (cylinder drop) between shifts, but you will want to quicken the shifts to reduce slippage by increasing the line pressure (also by programming the chip) or by installing a device to do this mechanically, such as a shift kit (better alternative). However, if you install a shift kit you do not want the program to increase line pressure or the shifts will be 'violent'.
I plan on getting a chip with a shortened (but not eliminated) TR and no line pressure increase to go along with my line mod valve that will soon be installed.
