Checking AF ratio
Yes if you want that kind of accuracy, but then why bother. You might as well hook up a computer if you need real accurate wide band O2 sensors.
But if he wants a good gauge that will work with the factory O2 sensor then they can be baught for 50-100 or so. Or you can make one for about 20 or so.
Either way the factory doesn't have a gauge in the truck to monitor this.
Originally posted by Flying ****
... That o2 sensor is bitchen if youre running an auto tap with extended parameters.
Is there anything else to do? I always thought that wideband o2 sensor had more wires then a standard o2 sensor.
