Forged crank??
Next up is machining a billet...
What exactly would a "not a true forged crank" be ?
The word forged has a very specific meaning:
forge:
To force a piece of hot metal into the desired shape by hammering it.
drop forged:
A part that has been formed by heating the steel blank red hot and pounding it into shape with a powerful drop hammer.
http://www.100megsfree4.com/dictionary/index.htm
forge:
drop forged:
I guess the pre 99's were cast steel?
4130 forged steel. These are a "twisted" forging. What this means is the crank is forged in a 180 degree flat plane, and while still hot the journals are twisted out to form the crankshaft. Although it sounds pretty drastic, this is the way that most OE manufactures make their cranks.
4340 forged steel. These are "non twisted" forgings, meaning that they are forged as is, with all the journals where they should be.
CAST STEEL crankshafts are as the name suggests cast from steel making them much stronger than the more common cast iron used in standard production engines.
HI!... All 5.4's have a forged steel crankshaft. Here's a pic of one out of a "98" 5.4 crate engine I purchased. It has been verified as forged steel by my engine builder.
https://www.f150online.com/galleries...4-794-6970.jpg
