Hellion scan tool feedback.
I am looking at buying a scan tool and want some feedback. I want a stand alone tool (no laptop). Prefer data log capable (I know the Hellion is not), trying to stay in the $300 range. Do any of these tools read the A/F numbers? Best place to buy? Looking for feedback on whatever brand you are using. The Hellion appears to be a nice simple user friendly tool. Guide me.
http://www.autoxray.com/scanners.htm
My OBDII Ford Enchanced Scanner is out having it's screen replaced. Once I get it back you can use it whenever you need to. I have the PC Up-Link Kit also for complete datalogging.
You can also borrow my Laptop/Generic OBDII Software if you want. It's been gathering dust ever since I got the AutoXray.
No A/F, but good data. (Timing, Short Term/Long Term Fuel Trim, O2 Readings, etc.) I can go over all the parameters with you.
It is a great little tool for 300 bucks.
It will give you long and short term fuel curves, timing, water temp, intake temp, throttle position, rpms, speed, 02 sensor readings, mass air voltage, things like that.
It will also read and clear codes in the PCM
It is not a profecional scan tool, but it ia also about 1/4 the cost. I drive around with it hooked up all the time, I have learned a lot about my truck since I have gotten it.
It has also come in handy a few times trying to figure out what is wrong with a few friends cars. In all cases it gave us enough info to fix the problem.
I have a AutoXray EZ Link hooked up in my truck right now. I am not sure what the readings should be, ie, Fuel Trim, O2 readings. Thanks for the reply.
