Intercooler has gone from green to brown!!!
Old 09-26-2002 | 08:41 PM
Lightning#838's Avatar
Thumbs down Intercooler has gone from green to brown!!!
I want my intercooler resuviour(sp) to be green again. Most people I've talked to say this is rust. How do I get the rust off so I can see green again!!
-Brian
Old 09-26-2002 | 08:48 PM
Don's Bolt's Avatar
Have you ever put ice in it??
What you have to do is drain it, fill it with distilled water and run it for a while. Then drain and refil with 50/50 mix of anifreeze and distilled water.
I allways use distilled water when I fill my radiator, ot intercooler resevour.
Old 09-26-2002 | 08:52 PM
Nope, never put ice in. Will the distilled water get all the brown off the sides?
Old 09-26-2002 | 09:36 PM
BlackLight's Avatar
Thumbs down It can also be this
Old 09-26-2002 | 10:34 PM
HD09319's Avatar
Thanks for the info!
Old 09-26-2002 | 11:30 PM
That's the intercooler recall for the intercooler under the supercharger. What I'm talking about is this.
My fluid is brown, not green. Anyone have any more info on this. Thanks
Old 09-26-2002 | 11:45 PM
frgetit's Avatar
Hmm...That's nuts. Do you think he's gettin' oil or supercharger lube in there or something?
Old 09-27-2002 | 12:14 PM
BlackLight's Avatar
Exclamation If there is a hole in the intercooler
you could be mixing fuel into your intercooler coolant circuit.
The antifreeze in the intercooler and intercooler radiator should prevent any rusting. So, if you never had only water in there, it can not be rust. It must be some other contaminant.
I would replace all the fluid and check it closely for a week or so for color changes.
How about a pic...
Old 09-27-2002 | 04:01 PM
Old 09-27-2002 | 04:03 PM
Old 09-27-2002 | 04:24 PM
slapshot's Avatar
Hmmmm, that is a strange color. I have never seen it turn that color. You may consider changing the coolant and see if it returns to that color quickly. Whatever made it turn, it can't be "normal" I wouldn't think.
Old 09-27-2002 | 07:05 PM
Lightningfun's Avatar
hMMM.....That almost looks like engine oil is getiting into the coolant somehow but I am not sure that is possible. Is your coolant kind of sludgy looking?
Tom
Old 09-27-2002 | 07:15 PM
Rob_02Lightning's Avatar
I agree about the possible oil getting in there, but without a quick course in intercooler 101 I couldn't tell you how that could possibaly be happening. From WHAT I CAN SEE IN THE PICTURE, it seems like a seperations of two differant fluids mixed in there.
THIS IS PLAINLY NOT A GOOD SIGN.
What Year L
How many Miles
When did this Start
Old 09-27-2002 | 10:31 PM
BlackLight's Avatar
Unhappy The level is too low as well...
Did you always own/service the truck yourself ?
It looks like there was/is something in there that does not react well with the antifreeze-water.
Old 09-27-2002 | 11:13 PM
frgetit's Avatar
That baby's got the runs....
Quick Reply: Intercooler has gone from green to brown!!!
