The 04 Lightnings
Re: The 04 Lightnings
Originally posted by theshyguy
What does everyone think will happen with the 04 L. Will its stay only a reg cab, flare side. Heard it may have twin chargers. One bad *** truck if it did.
05 will start the gen 3s with a TWIN SCREW CHARGER (not twin chargers).
Hope this helps
VINNIE
......... FuB
The "Twin Screw" Is like the Wipple Supercharger...... If you put The Eat0n and the Wipple next to each other......... Y0u would pick the wipple........... You get better b00st at low PSI.... With the Eaton you would have to bring the boost up to match the Wipple and l0w Boost levels... And plus the wipple Wines a little l0uder to..... Witch is Allways a Plus ! l0l
