Front wheel bearings
I ordered new front wheel bearings, races, and seals for the front of my truck. The parts came in today and the outter wheel bearing cage is plastic!? Anyone else done/seen this? First time I have ever seen plastic on a wheel bearing.
Now I have everything ready for my big brake install this weekend. I hope!
I pulled and greased the factory tapered roller bearings and replaced one seal on mine. I took off the rotors and had them turned. The bearings must come out if you remove the rotor. iner and outter.
Castle nut with cotter pin on the out side. A slotted washer..outter bearing. I pinched the inner seal on one. Why are you putting in new ones? Rough? Mine were fine I just repacked them. Guess it can't hurt..new one's that is.
