So I just dumped 2 gals of toluene in my L
And I still have top end detonation......I am thinking two things.
A: The toluene hasnt mixed in with my gas yet (15 gals), and I still need a chip reburn.
B: My plugs are gapped to wide. I gapped them to what i thought was about .44 , but it was with a *****ty plug gapper. Can that cause detonation???
Probably need to mix with the gas more, a suggestion the next time to try this, if you plan to have say 8 gals 93 and 2 gals toluene, I remember from racing GN's before that it was beneficial to put in 6 gals 93 and then mix 2 gals of 93 and 2 gals toluene. Then pour the mixed solution into the tank.I think it had something to do with toluene being bad for the gas tank? when poured directly in, hope someone else can chime in on this. I also feel your ratio of gas to toluene is a bit off and might be more advantageous with a closer ratio.
Originally posted by 1BADTK
Close the gap. try .036-.038
ditto on that one, get a nice feeler gauge and redo the gaps. .38 should be about right for your setup.
.44 is to big of a gap for a TR6.
you shouldn't need more then 93 octane gas cause the tuners don't make street programs standard with anything more then 93 octane.
