hey im installing the belltech rear shackles right now, and how did you guys get the top bolt out of the old shackle? mine is on the inside....... and the bolt is blocked by the frame thing. what did you do?
you need to jack the axel up a little bit until it clears the top of the frame, then take the bolt out, switch shackles, and lower it down a little and bolt the bottom back in. they are all that way
