Question about belt slip and boost actuator?
Some of you metion that you have changed pullies and are not getting the appropriate amount of boost. A lot of you say that this might be caused by belt slip. My question is, how do you know if your belt is slipping? Can you hear or feel something?
The other question is, what is the boost actuator that everyone mentions about? How do you know if it is set correctly? Where is it located?
The first question I have no idea, but the second question:
http://www.mdsonline.ca/svtmisc.htm
Hope that helps.
Hope that helps.
Originally posted by Don's Bolt
Follow the supercharger belt downwards fron the blower. Then you will see two black pulleys attached to a brace, Thats it.
I just called my buddy who let me borrow it to find out the name of the stuff........he is not sure but he works in the HVAC buisness and he said it is just used for sepentine belts at work, but he tried it before on his L and found the same results.
Anywho.......on a side note, I wish I would have made a sound clip of how loud my blower whine was at idle, it was crazy. It was literally 3 times as loud, just at idle. Sounded like an aftermarket Vortech on my truck
Greg (ib fast) even said something to me about it and he was 4 cars back in the staging lanes........I am sure he has heard some whine before with his 8# lower and 2 # upper
--Joe
Re: Question about belt slip and boost actuator?
Dan
