Which Wire Is TPS Output To The PCM?
I may be able to email you some Schematics from my Cd-Rom. Give me your email and I will try. I think you want the Gray/White wire (pin 89) from the PCM. Its on the bottom close to the center of the connector bolt. Because the Brown/White wire is a Reference voltage wire supplied by the PCM in order to measure the voltage drop (pedal position).
Orphaner,
If you could e-mail me a copy of the schematic, I would really appreciate it. Thanks in advance!!!.
Doug
BlownSVT2001@yahoo.com
Doug
