Mods = Smoked tranny = Big Money
Clarification?
OK-
Exactly what are all these tranny mods that can be made?
Line pressure is pretty clear... Is it necessary to raise the line pressure if you use the FT Line Mod Valve?
What is the stock "torque reduction" programming doing exactly? Is this the shutting down of 4 cylinders during WOT?
What about moving the shift points around? I know most tuners program the shift points to "allow" the tranny to downshift more radically at WOT in the 20-40 range.... Is that what's frying 2nd gear?
this board kills me,some time ago i remeber some of you bitching that ford is neglecting to many warrenty claims,now a guy gets his tranny replaced under warrenty and he is given **** over it!!!
BAH,good for you im hoping mines covered under warrenty when mine blows,it will make up for all the little **** they refused to fix(sqeaking brakes,paint peeling from the rims with less then 10k miles and the ****ty ****ty *** job that was done to repair the door crack problem that is still yet to be resolved!!!)
NOW take a deep breath and count to ten...........
Originally posted by Factory_Tech
Who told you it's impossible to smoke a tranny without mods? If you know how to do it, (and I do) you can burn up the tranny at will, with no mods. It's not even that hard to do.
Chips are hard on the intermediate clutch, at stock they're about at the limit, a few mods and you'll toast 2nd gear pretty easily.
G
G
Originally posted by kaleb
Sorry you feel that way Easterisland, If it makes you feel better I bought the Service Manager and his crew gift certificates to a restaurant next to the dealership.
BTW, I would have done the same thing you did if I could get away with it.
