NGK TR6's Ready to go in??
hey guys i just got the NGK TR6's spark plugs and i was wondering are they ready to go in the truck? are they all set or do i need to gap them or something, cause it does say on the box gap plugs to specs or something like that..... do i ignore that and put them in or what do i do?
spark plugs
It can be a little tricky if you have never don it before...Fisrt you will need the proper tools such as a spark plug gapping tool or a feeler guage. Both are available at any auto parts store. Basically gapping refers to adjusting the space between the center electrode of the plug and the outer electrode. Ford calls for .042to .046 for the L. I personally set mine at .042. When you get the tools, practice on a couple of older plugs until you get the hang of it. Then do all of the TR6's before you install them. Good Luck...
.040-.042" gap and DO NOT USE a "feeler gauge" They give false measurements on spark plugs. Only use a 'wire-type' gauge where the gauge will have different thicknesses of 'wire' that you slide between the two electrodes--looking for a slight 'drag' as you 'gently' push-pull the 'wire' between the electrodes.
And never use a plug that has been dropped!
Dan
Dan
