Help new owner with boost problem, please!
Hi everyone. I just purchased a 2000 L and am having lots of fun with it. However, my problem is that yesterday I decided to check out the boost and noticed to my dismay that when you WOT the boost immediately jumps to about 6lbs then falls and stays right at 5lbs. I tried this in every gear with same results. The only mods to the truck are a superchips chip (just firm up ****s, and timing), boost bypass (unplugged harness), and a borla catback. Any help would be appreciated. Can't wait to start the modding, once the truck is fixed of course.
1) Check the air filter.
2) Measure the lower pulley diameter
3) Measure the upper pulley diameter
4) Get an accurate gauge. Even a test gauge will work, plug in right under the steering column.
The trucks are great, the boost gauge is VERY inaccurate. Mine actually measures vacume while in a boost condition.
If the pulley diameters are good, then replace the air filter even if it seems like it's clean. You should be looking at 8-9 lbs boost with stock everything. If it's still under 8 lbs, I would check the intercooler, and make sure that it's clean. But that's a last resort, because it's more work.
Thanks for all the help, everyone. Just an update, I took the air filter out today and did a quick run up the street w/ no filter. Now the boost jumps to almost 9lbs, and slowly climbs to 9.5-10lbs. So at least I know its not an internal problem. I think I will be adjusting the boost actuator this weekend. Also, don't know if it matters but the TSB was never taken care of and I don't think I have a chance of getting it done now (I do have a warranty for 7 more months though). thanks again for all the help.
