headunit and subs??????
Head unit
Well, I can say that there is two wats to do it. #1 is to hook a line level converter to the radio harness splicing into the rear speaker wires, this wil enable you to use RCA wires to run back to the amp. The #2 way is kinda the same idea. if your amp has speaker level inputs you can spice into the speakers and get the same result. But not the same sound. If you do #1 you can take out you OEM head unit later without having to run the wires over. I hope this doesn't CORNfuse you
