Rear defroster
Originally Posted by AAlmeter
Harbor Frieght had these on sale for $5 each:
http://www.harborfreight.com/cpi/cta...emnumber=94592
I might give them a shot and see if I can't hook them up someplace safe and out of the way to blast on the rear window.
With any luck, they'll last more than a week.
Honestly went it comes to buying any electrical thing(s) for the house or my truck i buy the best quality that i can afford, it sounds ****y but im not risking my life by getting burned or losing my property that i worked so hard for just to say a few bucks. I dont mess with electrical things that dont seem reliable and that does not seem reliable enough to trust especially when it goes in the back where you can't watch it at all times.
I've got the Rear Defroster button on the dash, but don't think it works... I have a slider in the back, and while snooping around, found a small piece of glass behind the back seat... I'm thinking that my defroster glass was replaced with a slider after breaking. Does this sound logical? Does the stock defroster glass have the lines in it? My slider does not...
Please post a pic of the 'rear defrost' button... I'm curious to see it.
defrost
Originally Posted by wlgoble
Sounds like your truck had a defrost window and someone replaced it with a slider. You will see lines on a defrost window, sometime they are very faint. The slider will not have a defroster. Just about every other silverado has rear defroster, so im sure they come in F150s also. I just dont recall seeing one, though. King Ranch and Lariate owners chime in....Do you have rear defrosters?
Next Question: should I disconnect the Rear Defrost button on the dash? Don't want someone to turn it on and have loose cables feeding current to nowhere. Thanks.
I agree with your thought... I small found glass pieces behind the passenger seat, and there is some sort of Aftermarket sticker on the window that I hadn't noticed before. I'm sure that replacing it with a slider was cheaper than a defrost window from Ford.
Originally Posted by ws6_guyscrew
I'm glad my truck does not have one, i hate the look of the rear defrost and would hate for my tint to get melted ( if it would ) but thats just my opinion, not too sure if there is any type of thing like this available.
But on a serious note, using the OEM defrosters nothing will happen. They are so low powered and low heat. The elements get abt 85 - 100 degrees. Its hotter in the car in the summer.
