06 F-150
06 F-150 , CA-670, PKF1 Bypass, Installation Problems
I installed my CA-670 and everything works fine. I tried using a PKF2 with the wires wrapping around the coil ignition but it would not work unless the box was next to the ignition vs just the wires in a coil. I tried something else.
First off, will a PKF1 work?
I tried installing that but I can not get it working.
Install consists of :
TYPE B CONNECTOR
1 - PATS CONNECTOR - IGN - connected to red wire form module
2 - PATS CONNECTOR -Ground - NC
3 - PATS CONNECTOR - TX - connected to WHITE/GREEN from module
4 - PATS CONNECTOR - RX connected to GREY/ORANGE
MODULE
BLACK - CHASSIS
VIOLET - NC
GREEN - TX PATS CONNECTOR
BLUE - RX PATS CONNECTOR
RED - IGN PATS CONNECTOR
BROWN - Is this chassis ground or ACTIVE OUTPUT (NEG) BLUE/BLACK 6 PIN REMOTE START HJARNESS from CA-670
With BROWN from the module on chassis ground, the unit flashes the LED with no programming.
TYPE B CONNECTOR
MODULE
BLACK - CHASSIS
VIOLET - NC
Last edited by dennisfranz; 05-11-2007 at 08:16 PM. Reason: 06 F-150 , CA-670, PKF1 Bypass, Installation Problems
