Cb question
To adjust the SWR you will need a meter, probably it is high, if so cut a very small amount off of the length from the bottom af the antenna. Most Radio shacks can help or at least reccomend some one that can. Talk to some truckers [local] they always know someone close by that can check and set it. usually SWR interfers with reception but if it is really bad then it could interfear with reception.
