Throttle Body Spacers
If any of you are looking to increase your MPG for cheap, which I'm sure many of you are, I would recomend Poweraid's throttle body spacer. It separates the throttle body from the air intake by about an inch, with a spiral cut out of the spacer to form a helix-bore air spin, increasing the speed at which the air enters the throttle body. It installs with simple tools in about 25 minutes, costs around $75, with an increase of 2-3 MPG's.
HOSRACN
1999 F-150 Supercab 4X4 Offroad 5.4L V8
Black
Airaid Aircharger With K&N Air Filter
Poweraid Throttle Body Spacer
Glasspack Muffler With Split Dual Rear Exiting 18" Chrome Cannons
GTS Headlight/Taillight Blackouts
Window Tint
Billet Grille
Ford Hitch Cover
Upgraded Audio System With Aiwa CD Deck And 6 Additional Roof Speakers
HOSRACN
Black
Window Tint
Billet Grille
Ford Hitch Cover
HI!... HOSRACN : We all know about the POWERAID "junk" SPACER around here. 90% of people on this board bought it when it 1ST came out and many of us now have a $100 paperweight. I lost low-end torque, lost fuel milage and made my truck go 3 tenths slower in the 1/4 mile with the POWERAID spacer. Don't waste your money. If you want a cheap mod that works then buy a FIPG or ASP power pulleys. Someone here on this board even ran the PA spacer on a dyno and lost h.p. It may work on CHEVY's but it don't work on FORDS. In my honest opinion.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
That's kind of strange, A throttle body spacer just by definition should gain you torque, shouldn't it?
I am no engineer or anything but isn't that how they used to tune the old race engines for different tracks? Carb spacer and velocity stack length determined torque, HP and RPM range on those engines.
Don't know about milage increases but it should help out in low end torque.
By definition yes it should increase torque but, by trial and mishaps is the best paper weight I ever bought. Thats how it worked for me.
98 f150 4.6 auto 4x4 supercab-short box/bright red & black/6 disk cd changer/ dynomax cat back/k&n fipk/super chip/lund taillight covers/clear corner lens/factory fog lamps/pace edwards box cover/ultra wheels/LT265-75-16 BFG/ westin nerf bars/steel horse billit grill & bumper insert/reflex shocks/bosch plat. plus 4/accel wires/auto start/left hand grab handle/skidoo summit 700 high mark/FORD DEALERSHIP
