E-fan wiring----Will this work...
Anywhere there is a key on power source 12v works. I ran mine and tied into an unused spot in my fuse block (underhood). Later when I installed the missing relays for the trailer tow pkg, I had to redo it, forget where I put it but I think I spliced the wire underneath instead. I guess anywhere a key on 12v is present is ok, just a signal basically.
I found my Troyer instructions and mine say to connect the ignition lead to the white wire with a blue stripe under the Power Distribution box. However, it also says any wire that is hot when the key is on will do, so you are probably good to go. As far as the white/blue stripe wire goes, yours may be different because my truck is an '03.
