4.88's
4.88's
im gettin jus shy of 3k back from taxes this year so im buyin my 5"inch RCD lift for my 97 flareside 4wd reg cab. I already have the 35 inch tires and fancy new wheels. but since im gettin a good chunk of change back i figured i could regear right away too. especially since its got a 4.6
so my question is what have you guys spent on gears for your trucks...cost and installation?
i want to do 4.88's front and rear
but hey i posted pics of the parts in the thread take a look,
I paid $1100 here in nebraska at a local shop parts and labor. Most places wanted waaay more. This shop let me take them just the differentials, they installed the gears, then I reinstalled them on the truck. The brand of gear will make a difference in cost too, but dont get a cheap one.
thanks for bringing that up noblem
I had a 98 model and ran 40inch swampers with 4.56 precision gears. It was a perfect gear ratio to tire diameter combo. 4.88's will work but I don't think you'll need them that low, when I got the rear end apart I noticed a clearance issue between the ring and housing. I don't believe I could've fit 4.88's or lower because of the thickness of the ring.
I did the install myself but $1000 to $1250 for gears and install is all would pay.
exactly. the 38's are gonna have to wait a little. i need my wider wheels, can't run 13.50-14.50 in tires on stock 7.5 in rims, lol.
and i'm not running 38's on stock gears. my buddy has went through two transmissions so far on his 03 w/ 38's and stock gearing.
so, the 38's are coming after the wheels and gears, i may not get the bigger tires for another six months or so.
Cant wait to play with the 5.4 now
i geuss its not even a fair contest anymore
