Hardwiring A NUVI ?
#32
I had a kid at the local audio store do mine when he installed the backup camera. He ordered a $17 wiring harness....and took about 10 minutes. I put mine (Nuvi 255W) left of the steering wheel..stuck to the windshield. Also did the backup camera with a 2.5" screen mounted on the defroster vent on the driver side door....looks very clean. I'll try to get some pics posted. (2010 XLT Screw)
#34
Had my Nuvi hard wired to the igintion....don't like it. It goes on and off everytime the key is turned on, and I need to shut it off manually if I don't want it on. Taking it back to the kid that did the install to either have it wired hot or switched. IMO having it cycle through the start up everytime I get in the truck is annoying. Hope this helps.
#35
#37
#38
I think his main issue is he didn’t want it on every time he turns the truck on. I think it would be easier to leave it switched like it is and just turn it off when you don’t want it on then to have to turn it on and off every time. You could also leave it switched and put a toggle switch inline also so that it only turns on when the ignition is on and the toggle switch is in the on position.
