RoadArmor help/questions
Aright guys I ordered a RoadArmor Pre-Runner for my truck an it should be here wed at the latest. Then it goes to linex to be xtra'd and paint matched.
But anyways, I had originally planned on using KC 5" fog and long range in the light holes but I was told KCs will not fit in the holes/mounts without modification to their mounts and to just use PIAAs.
First I would like to know if anyone knows if this is true or not and second which PIAAs will fit in the 5" holes? (Which series is the 5" size)
Sucks cause PIAAs cost too much an I can get KCs extremely cheap
Thanks again guys
Sean
Thanks again guys
Sean
easiest ans safest way of putting on a bumper like that is with 2 or 3 people.
But if you want to do it yourself, this is what you do:
*Take some rope tie it to something up in the air, tree limb, swing set... etc
*Take some measurements from the heigth it will be mounted at:
*Hang the bumper from the road at that high, using a jack to get it up to the rope.
*Then drive the truck up to where you have the bumper hanging
*Remove the jack and slide under the truck
*Now you can swing the bumper and fiddle with it without worrying about 100+ pounds falling on you
*Throw on a nut and bolt on both sides to secure it.
*Remove rope
*Finish install, and fiddling to line up while leaving atleast 1 nut and bolt secure on both sides
*Remove rope
i didnt literally mean by myself ill have a couple friends to help but i thought i read/heard somethin bout havin to cut the front frame horns down an i was wondering if it was true
thanks alot jake and I live in West Columbia about 30/40 min south of houston. But the stock bumper is trashed from my wreck and they wanted $1k for a new one which is why i got the road armor.
