air horn relay queston
If you are using the lead to the horn ( pos trigger from the horn relay to the horns ) terminal 85 would be wired to the horns, and terminal 86 is ground.
The clock spring switches the ground on the factory horn relay.
Terminal 85 should be to the horn wires, the Yellow w/ Green stripe wire.
