performance plugs
Old 06-27-2010, 01:52 PM
Pitbull_Rott's Avatar
performance plugs
do the 3 and 4 prong bosch platinums really give better mpg and more hp?
Old 06-27-2010, 03:58 PM
Old 06-27-2010, 10:43 PM
i heard something about a ford flip chip. do you know what that is?
Old 06-27-2010, 10:51 PM
Hespen537's Avatar
Its a performance chip. A lot of people buy it to save gas. They make them for diesels and gas engines. They have a wide range in prices. Some of the diesels will throw codes if there not set right.
Old 06-28-2010, 02:02 AM
97XL's Avatar
Since no one has said it yet..I will.
DO NOT PUT Bosch plugs in the 4.2..EVER...
The 4.2 is a very picky motor when it comes to plugs. I tried a set of Bosch..truck ran so rough I thought it was gonna shake apart. Put the old plugs back in and it ran smooth. I then put in Autolight Dbl Plats and it ran fine for 3 yrs. Just recently put in a set of motorcraft plugs and no issues.
Now there are some rare cases where the Bosch plugs worked but I can show you multiple threads on a v6 forum where my advice is backed up by tons of posts.
Best to stick to the following..Motorcraft, Autolite, Denso Iridium..there is one other but I can't remember the name but it sure ain't Bosch.
Old 06-28-2010, 03:21 AM
NEVER EVER EVER purchase a canned tuning device, check out the chips/tuners section read the sticky's and you'll why the SCT XCal3, PHP Gryphon, SCT Livewire, Sniper and Diablo are the common ones
Old 06-28-2010, 05:17 AM
jbrew's Avatar
do the 3 and 4 prong bosch platinums really give better mpg?
Yes.
Because when they heat up and melt, they fall apart in the cylinders and screw up the valves (among other things).
So you will achieve much better mileage, - because the damn thing won't run anymore.
Old 06-29-2010, 11:44 AM
IR0NS1N's Avatar
We had a car come into the shop with a set of bosch plugs that came apart in a chevy malibu. Put a hole in piston number 4 the size of a quarter.
Stick with motorcraft or autolite for Fords. However I run Brisk plugs for higher boost over the motorcraft HT0
Old 06-29-2010, 04:00 PM
jbrew's Avatar
I started using Iridium's for the first time two and half years ago in my 98 5.4L. I updated the coils and forward O2 sensors at the same time. Fuel mileage has been consistent @ 16 city/ 16 highway. Yea, I get the same highway/ cruise set to 78 mph @ 2200 rpm. I'm not complaining, -I'll take it.
IMO, for the two valves, - the iridium will keep them at peak performance the longest.
More 2V Info~
Also, - The Autolite 103/104's are the wrong heat range and don't meet Ford spec. Honeywell has had both contracts for along time (Autolite, Motorcraft). Motorcaft plugs are spec'ed by Ford, -Autolites are not AND for the two valves, they are different. Not sure what happened there, but they over heat as well. Now they don't fall apart like the Bosch, but they can get hot enough to misfire/foul.
Two valve plugs, stick with these:
Denso
NGK
Motorcraft
Old 07-17-2010, 10:48 PM
today i bought the bosch 2 prong plats and put them in. btw, i found autolites in my truck when it was supposedly sposed to come with motorcrafts? anyway, i noticed a smoother startup, better and smoother acceleration, and when i gas it the truck responds quiker. i like them way better than the old ones. i bought the truck new and ever since i bought it, it always had weird startups and would take a second or so to respond when pressing the gas
Old 07-26-2010, 12:40 AM
E3 plugs in 4.6
Quick ? I have a 2003 4.6 w/ 112,000k miles. Have a few upgrades, consisting of: Spectre Cold Air Intake, Poweraid Throttle Body spacer, Hypertech 160 degree thermostat, and strait exhaust. I recently installed the E3 plugs, seems like its running better, and getting a lil better gas mileage. But ive seen some forums about the 4.6s being picky about plugs. Ive had good luck w/ them, just wondering if anybody hasnt or if anybodys heard bad things. Thanks
Old 07-26-2010, 06:20 PM
put down the keys
back slowly away from the vehicle, (you've done enough and you don't need to make it worse by scaring the poor thing)
once you are at least 200 yards back you need to turn and run as fast as you can to a bicycle store...
Old 07-26-2010, 06:53 PM
Good plugs to use with the 2V.......
Denso
NGK
Motorcraft
Old 07-26-2010, 06:55 PM
IR0NS1N's Avatar
straight exhaust
E3 plugs
nothin like abusing the smilies!
Old 07-26-2010, 07:11 PM
These are out of a yota but still the same results will happen in a Ford.
Here's a 4 pronger from jbrew's album.
Quick Reply: performance plugs
