removing fan from water pump pulley
yeah they gave me a tool for removing clutch fan but im gonna have to tak it back, smallest wrench was 40mm and thats still a lil too big. problem im having is how the heck to hold the water pump pulley snout still, while i turn the fan to loosen it. it wants to turn the pump pulley with the fan getting me no where
alright got the boxy u wrench, it seems to hold the water pump it came with a 54mm boxy u wrench to hold the water pump, anyone have any idea what size the fan actually is? it came with a 40mm wrench but its to large a bit for the fan. what do u fellas recomend to use on the actual fan? is it a 36mm? did u just use a adjustable wrench? i got this thing licked if i can take the fan off.. thanks for the info on the boxy u wrench patman, turns out i had my head in my **** and didnt even think the tool i had was to hold the water pump. i was just using it to turn the fan off the water pump.. thanks alot again, man i feel like a real rocket scientist..
still having a heck of a time im alsmost to the point of paying to have the fan took off. shoot i can do the rest.... wish i woulda put this on when i installed underdrive pulleys, wishing now i wouldnt have put the fan back on with that air chisel attachment.. though it was quick id love to have an air compressor and air chisel again.
Mine required a 1-7/16 or 1-3/8 open end wrench. I can't remember which end of the combo it was - I think the 1-7/16 though.
It should not take more than a good bump to break the fan loose. If you can get someone to hold the wrench on the pully, just bump the wrench on the fan with a short handle sledge hammer - just make sure you are turning the correct direction.
