e-fan install help
e-fan install help
i just wired up my fans and have it wired to switches as well. well it has three wires comming out of it and i guess i forgot to run the low speed. what size relay should i use? also for my high speed (and god it sounds like a air plane) i have a 30 amp relay on it when on everything is fine but when turned off the wire comming into my switch from 12v heats up like right now and starts smoking ! is the relay too big? not holding enough power back when its off?
please help
please help
FINALLY got them working and going good. no overheating!
thanks patman for making me think stight.
i figured the efans would cool better than my stock one but it is darn near the same. its within the same range....... what did everyone gain by doing the swap ACTUALLY? not hear say but what did you notice when you put them on? i dont feel any difference. some said better throttle response. none. better miliage. maybe .5 and nothing as far as power????
i guess i expected more for the money i paid. i noticed more from my throttle body spacer than this, and everyone says that it crap!
please set me stright!
E-fans won't cool any better than stock...the thermostat takes care of that. as far as the other benefits go..they will be felt over time..I have the feeling you was expecting a night and day difference in performance..won't happen! You will get a little better throttle response and somewhat better mileage over time. There are very few things that will pay for itself as far as mods are concerned, the biggest gain overall is custom tuning. All that being said, nothing that you can do will pay off big in the end other than a better running and more responsive truck overall.
