Rear window leaking
Rear window leaking
My '98 has suddenly developed a leak on the passenger side rear window right next to the center slider. It leakes from the headliner area. Anyone have any ideas? Not sure if I should remove the headliner to look for the leak or use some silicone around the windows on the outside. No change made at all and slider shuts fine.
Was not sure where to post this issue.
Search is your friend....
How to Fix the Leaky Rear Window...
357 Returned Results for 'Leak Rear Window' here at f150online.com
Enjoy.
Enjoy.
What you're describing is a common problem in the 97 and up F-150. If you have a slider, it'll have to be replaced by a qualified glass shop. It's not recommended that you attempt to pull and reset a slider of this model as the glass and frame will seperate during extraction and the frame can crack. If you have a solid backglass, you can have it pulled and reset. I'm a professional autoglass tech and I deal with this almost everyday. I had the same thing happen on my 98. By the way, don't use silicone on automotive glass, it can do more harm than good. Feel free to ask me any glass questions you have including how to take it apart.
