2007 Rear View Mirror with Camera
Old 07-28-2007, 12:42 PM
MeanGene's Avatar
Does anyone know if they are going to make the Auto-dimming, rear view mirror with a backup camera available for the earlier F150's?
Old 08-05-2007, 01:31 AM
Steve83's Avatar
Old 08-05-2007, 01:55 AM
I12AV82's Avatar
i think I'm under a rock - is this a 2007/8 model year option?
Old 08-10-2007, 05:05 PM
MeanGene's Avatar
It's a 2008 option.
Old 08-21-2007, 02:23 PM
MercedesTech's Avatar
anyone know if you get that same set-up for a 2004? That Mito website doesn't have the same style back-up camera for a Ford.
Old 08-25-2007, 05:22 PM
Steve83's Avatar
Did you look on the Monitors page? That mirror will go in just about anything that runs on 12VDC. And so will all their cameras.
Old 09-14-2007, 12:19 PM
aflores61's Avatar
Question
Anyone know the part number for the Ford OEM Tailgate backup camera. Specifically the ones that are on the 2008 F-150's. I wanted to add one to my F-150, but I needed some info like is there a paint to match version and does the oem camera have a video cable that could plug in to a DVD head Unit instead of the mirror.
Old 09-14-2007, 05:57 PM
MeanGene's Avatar
Yes, I got a quote from a Ford parts distributor who is usually quite low.
Back up Camera: $226.05
Rear View Mirror: $502.66
Tailgate Handle: $71.15 (black) or $104.23 (painted)
Wiring Harness in Gate: $219.99
Wiring From gate to Main Harness: Price not available yet
Wiring in roof for mirror: Price not available yet
He tells me that you can find similar backup camera for a lot less.
Old 09-14-2007, 10:50 PM
aflores61's Avatar
Would you happen to have the part number for these parts or a contact number to your parts dealer?
Old 09-15-2007, 01:06 AM
MeanGene's Avatar
You can contact Dominic at Tasca Auto parts for the numbers.
Old 09-15-2007, 12:07 PM
MeanGene's Avatar
You might want to save yourself some money and look at something like this instead.
Old 12-09-2007, 01:05 AM
coblue's Avatar
Got one of those at the local parts store ($99) for my wife to ease hooking up the trailer. A little tough to judge distances, but definitely helps overcome the the high tailgate on the newer trucks. Had to shim the camera in order to see the hitch ball, but an easy install otherwise.
Old 12-09-2007, 10:15 AM
aflores61's Avatar
Exclamation
Well I changed my backup camera to the Tailgate handle. I bought the OEM tailgate handle and then added an aftermarket camera. The had to modify the handle a little though. The OEM camera fits inside the handle, with the aftermarket one it sit outside of the handle and I also had to widen the hole a little, but it works very well and doesn't look that bad.
Changed from this:
Edge Camera $240.00
To this:
Tailgate Handle $109.00
Camera $25.00
Old 12-09-2007, 10:56 AM
MeanGene's Avatar
Changed from this:
Edge Camera $240.00
To this:
Camera $25.00
I am interested in more of the details. Why, how much, what camera are you using, did you get the wiring harnes too. Why not go wireless?
Old 12-09-2007, 11:29 AM
aflores61's Avatar
I chose this method because the wiring was already there from the other camera and I plan to add a 12" Rize lift to the truck so it will be sitting pretty high. The angle from where this camera sits actually covers a big blind spot that will result from the lift height, wiring was pretty simple I just bought the wire harness that the seller of the camera sold, the link to the camera I used is below. I just ran the wire through the hole at the bottom of the tailgate and thats it. The camera cost $24.99 plus $12.01 for S&H
http://cgi.ebay.com/Wide-Angle-120D-...QQcmdZViewItem
Quick Reply: 2007 Rear View Mirror with Camera
