New Eaton Posi, bad gear oil smell
Old 12-26-2002 | 12:48 AM
LoCo F150's Avatar
I gave up on the powertraxs, and tried the eaton posi, so far, less noise and seems to be pretty smooth and work a little better. I had the mechanic put some amsoil gear oil and some friction modifier, but i was driving out of town and i can smell a really bad gear oil smell, i look under the truck and where the driveshaft connects to the rear end i can see some smoke on top of the rear end casing. could this be some gear oil that could have leaked out or could the gears be getting to hot? im not sure what it is, but it scares me and i hate the smell, never had the prob before.
Old 12-26-2002 | 01:01 AM
mscott's Avatar
Is the stuff you put in with the Eaton synthetic? I heard you shouldn'r run synthetic until you've broken it in.
I have an Eaton Posi in my 74 Nova and can't say I recall having a similar smell from the outside. Of course the old fluid smelled like **** but it was very old.
Really like the Eaton unit personally.
Old 12-26-2002 | 10:21 PM
LE PEW's Avatar
Sorry to hear about your dislike for the Powertrax. I was considering it as an option to my LS sometime down the road.
I dont think that your pinion should get hot enough to make smoke like you say. It seems to me that something is not right and you should get it checked out.
Good luck.
Old 12-26-2002 | 11:32 PM
LoCo F150's Avatar
well i found out what it is, the rear end is only leaking a hair, but ill get it fixed, but other than that everything else seems to be fine, thanks for the help guys
Quick Reply: New Eaton Posi, bad gear oil smell
