What size rear end do I have?
Ford hasn't used the 9" axle under trucks since about the mid 80s.
You can also look at your axle tag to make sure as well. Mine with 3.55 diff and 8.8 axle reads something like this
3 8.8 55 O or at least something along those lines.
You can also tell the difference by looking at the diff housings. The 8.8 is more of a sqaure shape with very rounded corners on it and the 9.75 is almost more of a hexagonal shape. If you look at them side by side its pretty obvious.
