4x4 ratio
If its factory, then its 3.55 open. Factory gear ratios are matched, if they're not then you destroy the transfer case, drive shafts, and axles. Its also going be open since Ford doesn't offer any kind of LS or locker for the front axles from the factory.
If you really wanna look for yourself there is a metal tag on the front pig that has the axle code on it that says what gears and what kind of carrier it has.
